Dołącz do naszej Grupy na FacebookuInsignia DPF Info - aplikacja na Androida
bartekb14
u mnie 6 bieg obroty 1800-1900, prędkość około 130, wypalanie zawsze do 7%.
Adrian85Wawa
Ping pisze:Dla posiadaczy silników B20 mam dwie wiadomosci. Jedną dobrą a drugą złą.
Zła jest taka, ze w przeciągu najbliższych 6 miesięcy nie planuję wypuszczać aktualizacji aplikacji. Musze ją przebudować tak żeby działała szybciej i była bardziej elastyczna na modyfikacje a nie będę miał czasu żeby poświęcić na jej rozbudowywanie i pisanie w zasadzie od nowa.
No a teraz ta lepsza.
W internecie zaczęły wypływać już PIDy pomiarowe dla tych silników, tj B16DTx, B20DTx.
(Parametry te nie będą obsługiwane w silnikach A20DTx, przynajmniej te dotyczące DPF)
Żeby skrócić wam poszukiwania, poniżej zamieszczam listę najważniejszych:
[/size]Kod: Zaznacz cały
"Name","ShortName","ModeAndPID","Equation","Min Value","Max Value","Units","Header" "OPEL Astra-K Distance Since Last DPF Regeneration","Dist. DPF","223039","A*256+B","0","65535","km","7E0" "OPEL Astra-K DPF Differential Pressure","Diff. press.","2220F4","SIGNED(A)","-128","127","kPa","7E0" "OPEL Astra-K Calculated DPF Flow","DPF flow","2220F5","A*0.01","0","2.55","kPa","7E0" "OPEL Astra-K DPF Differential Pressure Sensor","Diff.pres.sen","223035","A*5.5/255","0","5.5","V","7E0" "OPEL Astra-K DPF Regeneration Status","DPF dif.stat","2220FA","{A:0}","0","1","req/notreq","7E0" "OPEL Astra-K DPF Soot Accumulation","DPF Soot","22336A","A*100/255","0","100","%","7E0" "OPEL Astra-K Average DPF Inlet Temperature During Regeneration","DPF Inlet temp","2220F8","(A*256+B)*0.1-40","-40","6513","degree C","7E0" "OPEL Astra-K DPF HO2S 1","HO2S 1","220034","(A*256+B)20/255","0","20","Lambda","7E0" "OPEL Astra-K DPF HO2S 1 Oxigen Concentration","HO2S 1 Conc.","2220FD","(A*33.55/255+B*0.13/255)-12","-12","21.68","%","7E0" "OPEL Astra-K DPF HO2S 2 Oxigen Concentration","HO2S 2 Conc.","2223AD","(A*33.55/255+B*0.13/255)-12","-12","21.68","%","7E0" "OPEL Astra-K TCM Temperature","TCM temp","22280D","A-40","-40","215","degree C","7E2" "OPEL Astra-K Remaining engine oil life","Rem.eng.oil","1A6D","A*100/255","0","100","%","7E0" "OPEL Astra-K Sensor 1 IAT","1 IAT","22000F","A-40","-40","215","degree C","7E0" "OPEL Astra-K Sensor 2 IAT","2 IAT","222006","A-40","-40","215","degree C","7E0" "OPEL Astra-K Fuel rail pressure sensor","FuelRailPres","220023","(A*256+B)*0.01","0","655","MPa","7E0" "OPEL Astra-K Turbocharger Vane Position Sensor","TurboVaneSens","221543","A*100/255","0","100","%","7E0" "OPEL Astra-K EGR Position Sensor","EGR Sens","221152","A*100/255","0","100","%","7E0" "OPEL Astra-K Coolant temperature sensor","Cool sens","220005","A-40","-40","215","degree C","7E0" "OPEL Astra-K MAF sensor","MAF sens","220010","(A*256+B)*0.01","0","655","g/s","7E0" "OPEL Astra-K Engine speed","Engine speed","22000C","(A*256+B)*0.25","0","8000","rpm","7E0" "OPEL Astra-K Engine load","Engine load","220004","A*100/255","0","100","%","7E0" "OPEL Astra-K Counter check Engine Oil Pressure Regulator","EngOilReg","221C1A","A*256+B","0","65535","counts","7E0" "OPEL Astra-K Fuel level sensor","FuelLevSens","221155","A/51","0","5","volt","7E0" "OPEL Astra-K Fuel remaining","Fuel Rem","22132A","(A*256+B)/64","0","50","litres","7E0"
Lista jest dla aplikacji Torque PRO, w wersji darmowej tego programu parametry nie będą działać.
Parametry te można wklepać ręcznie, albo zaimportować z pliku.
Parametry te są zbieżne również z nowszymi silnikami A17Dxx które nie działają w mojej aplikacji. Nie będzie chyba tylko odczytu zapełnienia Soot Accumulation bo z tego co zauważyłem, te silniki go nie obsługują.
Drobna uwaga,
W parametrzeZ tego co pamiętam to formuła powinna być "A" zamiast A*100/255", czyliKod: Zaznacz cały
"OPEL Astra-K DPF Soot Accumulation","DPF Soot","22336A","A*100/255","0","100","%","7E0"Kod: Zaznacz cały
"OPEL Astra-K DPF Soot Accumulation","DPF Soot","22336A","A","0","100","%","7E0"
Witam jestem nowy na tym forum. I moja iske posiadam od miesiąca 2016r B20dth . Pytanie moje dotyczy tych pidow gdzie je skopiować w Torque pro? Tak wiem w ustawieniach wybrać dodatkowe PIDY czujniki ale jest tam kilka pozycji. Skopiowalem te PIDY i wkleiłem w pierwsza tabelkę i po teście wyskakuje błąd. Prosiłbym o dokładny opis czynności krok po kroku jak mam to zrobić bo jestem zielony w tym. Z góry dziekuje
- xmax
- Auto: Vauxhall Insignia
- Miasto: Londyn / Białystok
W Londynie i okolicach raczej ciężko jechać jednostajnie, dlatego nie staram sie za wszelką cenę wypalać jak najlepiej, było nawet 38% po wypaleniu, korek na autostradzie i podjezdzanie po kilka metrów. Czasem jak jadę dalej to staram się żeby wtedy wypalić poniżej 10.kecraminsignia pisze:No to wy musicie jechać szybciej. Najważniejsze aby w miarę jednostajnie. Tak aby w trakcie wypalania nie było dużych odchyleń w chwilowym spalaniu.
Jak wzniesienia to wcześniej przewidywać.
Wysłane z Xperia XZ Premium
- Auto: Insignia B ST
- Kod silnika: B16SHL
- Otrzymał piwo: 146 razy
Spróbuj wpisać ręcznie.Adrian85Wawa pisze:Ping pisze:Dla posiadaczy silników B20 mam dwie wiadomosci. Jedną dobrą a drugą złą.
Drobna uwaga,
Kub@
- Postawił piwo: 6 razy
Popatrz w inne PIDy jaki jest styl i sposób zapisu, nie powiem trzeba trochę przećwiczyć zapis nowych
Przy okazji -....
Ping, czy to normalne wskazanie w "DPF Soot Accumulation"?
Jak odpalam auto to mi pokazuje 7, 8 % nawet po przebiegu 500 km od ostatniego wypalania. Poza tym po przejechaniu kilku dziesięciu kilometrów potrafi wartość zmniejszyć się o parę %.
Przy okazji -....
W jakim silniku?
tetar
- Auto: Ins ST Sport
Ping, czy w aplikacji DPF Monitor są ikony alertów, które wyświetlają się na ekranie gdy np. przekroczony jest stan jakiegoś parametru?
Tylko oleju.
tetar
Pomarańczowe kółko z "oliwiarką"?
Taka ikona pojawiła się na chwilę w rejonie prawy dolny róg ekranu na polu RPM.
Co ciekawe było to w trakcie manewru - dosyć ostre ruszenie ze skrętem w lewo jakby siła odśrodkowa zabrała olej z części silnika i być może stąd ta ikona. Biorąc pod uwagę, że wcześniej miałem na wyświetlaczu 2 x info o niskim ciśnieniu oleju...może to kolejny symptom problemu z uszczelką może niski poziom oleju?
- Postawił piwo: 19 razy
- Otrzymał piwo: 145 razy
No chyba poziom oleju umiesz sobie sprawdzić?
tetar
W miesiąc temu w ASO miałem wymieniany rozrząd z olejem, czyżby chłopaki zrobili fuszerkę olejową?
- soulck
- Auto: 2.0 Ecoflex
- Miasto: Kielce
Panowie jaki czort? Icar II przestał sie łączyć z komputerem. Po wpięciu w gniazdo zabłyśnie niebieska ikonka ,zielona i czerwona świeci się na stałe. Aplikacja z tele nie może się połączyć z tym "maleństwem" Ktoś coś?
Używałes innej aplikacji?
Zainstaluj ELM327 Identyfier i przeskanuj interfejs. Potem sprawdź czy apka zadziała.
- soulck
- Auto: 2.0 Ecoflex
- Miasto: Kielce
Nie tylko Opl Dpf Monitor Lite. Możliwe że coś nie tak zrobiłem?
Raczej nie.
Sprawdź program i którym napisałem.
- soulck
- Auto: 2.0 Ecoflex
- Miasto: Kielce
Ok. Tak zrobię
-- 6 mar 2018, o 16:49 --
No niestety. Z tym Elm 327 Identyfier też się nie łączy....
-- 6 mar 2018, o 21:14 --
Jutro zareklamuje Icar II. Bo teraz nawet włączyć się nie chcę ...
A sparowałeś telefon z elmem?
Widzi go?
Teraz jak było zimno mój też przestał działać, musiałem na nowo go sparować.
Widzi go?
- soulck
- Auto: 2.0 Ecoflex
- Miasto: Kielce
Tak. Parowanie jest ok. Robiłem ze dwa razy. Telefon go widzi. Bluetoth działa w tele iłączy z autem ...
Ale I car II po wpięciu w gniazdo świeci na czerwono i zielono a niebieska środkowa dioda tylko raz zabłyśnie i tyle... A po próbach włączenia go przyciskiem zero odzewu.
A 3 dni działał.
A 3 dni działał.
