ECP 4
Putridum
ECP 4
Post autor: Putridum » 30 maja 2015, o 17:14
mam zainstalowane Opel ECP 4 ale za cholery nie mogę go uruchomić - ECP zaistalowane jest na virtualbox (win xp z dostępem sieci) - i nasuwa się pytanie w czym błąd
błędy podczas uruchomienia:
Kod: Zaznacz cały
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'epcGmeLicensor' defined in ServletContext resource [/WEB-INF/contexts/epc/gme/gme-common-lic.xml]: Cannot resolve reference to bean 'epcGmeLicensorUtils' while setting bean property 'licensorUtils'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'epcGmeLicensorUtils' defined in ServletContext resource [/WEB-INF/contexts/epc/gme/gme-common-lic.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (
Java Client Version 3.0 Build Rel20070803(327 CanTa)
TB Java Server error <11035>: TransBase Multiplexer error report:
database <GME_ROM_1@tomek-3864eaefd> does not exist
	org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:274)
	org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1274)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1042)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:539)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:485)
	java.security.AccessController.doPrivileged(Native Method)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:455)
	org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:251)
	org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:169)
	org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:248)
	org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:170)
	org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:413)
	org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:735)
	org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:369)
	com.proquest.pbs.mace.context.SecuredChecksumXmlWebApplicationContext.refresh(SecuredChecksumXmlWebApplicationContext.java:49)
	com.proquest.pbs.mace.context.WarWebContextBuilder.buildContext(WarWebContextBuilder.java:382)
	com.proquest.pbs.mace.context.WarWebContextBuilder.buildContexts(WarWebContextBuilder.java:320)
	com.proquest.pbs.mace.context.WarWebContextBuilder.buildContexts(WarWebContextBuilder.java:333)
	com.proquest.pbs.mace.context.WarWebContextBuilder.buildContextHierarchy(WarWebContextBuilder.java:250)
	com.proquest.pbs.mace.servlet.ControlServlet.createWebApplicationContext(ControlServlet.java:90)
	org.springframework.web.servlet.FrameworkServlet.initWebApplicationContext(FrameworkServlet.java:266)
	org.springframework.web.servlet.FrameworkServlet.initServletBean(FrameworkServlet.java:236)
	org.springframework.web.servlet.HttpServletBean.init(HttpServletBean.java:126)
	javax.servlet.GenericServlet.init(GenericServlet.java:212)
	org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
	org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:261)
	org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:852)
	org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:584)
	org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1508)
	java.lang.Thread.run(Unknown Source)
root cause
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1362)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:540)
	org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:268)
root cause
	org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82)
	org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:552)
	org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:616)
	org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:641)
	org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:673)
	org.springframework.jdbc.object.SqlQuery.execute(SqlQuery.java:112)
	org.springframework.jdbc.object.SqlQuery.execute(SqlQuery.java:122)
	com.proquest.pbs.mace.gm.dao.CountryLangJdbc$GetCountryLangsByCountry.execute(CountryLangJdbc.java:90)
	com.proquest.pbs.mace.gm.dao.CountryLangJdbc.getCountryLangs(CountryLangJdbc.java:39)
	com.proquest.pbs.mace.gm.bus.CountryLangBusImpl.getCountryLangs(CountryLangBusImpl.java:34)
	com.proquest.pbs.mace.gm.lic.GmLicensorUtils.cacheDataLanguages(GmLicensorUtils.java:154)
	com.proquest.pbs.mace.gm.lic.GmLicensorUtils.afterPropertiesSet(GmLicensorUtils.java:60)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1390)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1359)
root cause
	org.apache.tomcat.dbcp.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
	org.apache.tomcat.dbcp.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
	org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:113)
	org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:79)
root cause
transbase.tbx.TBException:
	transbase.tbx.TBException.a(Unknown Source)
	transbase.tbx.java.b.e(Unknown Source)
	transbase.tbx.requests.j.<init>(Unknown Source)
	transbase.tbx.java.b.<init>(Unknown Source)
	transbase.tbx.java.c.a(Unknown Source)
	transbase.jdbc.Connection.<init>(Unknown Source)
	transbase.jdbc.Driver.connect(Unknown Source)
	org.apache.tomcat.dbcp.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
	org.apache.tomcat.dbcp.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
	org.apache.tomcat.dbcp.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
	org.apache.tomcat.dbcp.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.13 logs.
Pruski
Auto: Insignia 4x4
Re: ECP 4
Post autor: Pruski » 30 maja 2015, o 19:01
Putridum wyszukaj w googlach sobie 'Opel EPC peb' i na ostatniej stronie tematu z pierwszego linku wyników jest ładna instrukcja, której ja używałem ;)
Putridum
Re: ECP 4
Post autor: Putridum » 30 maja 2015, o 22:11
tja taki mądry to i ja jestem
yerry
Prezes ICP
Auto: Insignia B GS
Postawił piwo: 26 razy
Otrzymał  piwo: 99 razy
Re: ECP 4
Post autor: yerry » 30 maja 2015, o 22:48
Zgłoś błąd do producenta softu. Oprogramowanie jest na wsparciu, jeśli masz podoblem - pomogą.
Wróć do „Inne”
